Athlon XP 2400+ overclock
r4d
Can anyone give me a few tips on overclocking
my xp2400+ on my kt400 soyo mobo.
512mb of mem 133.3 mhz (1:1)
heres some ss of how far i've made it, with system stability.
(yes its pretty bad)
The first image on the left is my default. I'm air cooling but temps
are fine, so not worrying too much about that unless i push it pretty far.
Try 12.5 x 166, 12x180, 13x166, I have a 2400xp t-bred and it works good at 12x180.
not much you can do with that mem and mobo. now, if you had PC3200 DDR and a Nforce2 MoBo, then you could have some fun. :D
you really need to look at an nforce2 board if your gonna be overclocking. and as stated above. you need good ram also.
DC
thx guys. can anyone recommend the best or one of the better nforce2 mobos
