RobotChild
- Jul 4, 2006
While swapping out my 2600+ to test my old un-used 1500+, I failed to lower the FSB to 100Mhz, from 166.
After DXDIAGing and noticing what I've done, I decided to stress test.
After 1/2hour of SP2004, and a low load temp of 42. I'm quite happy.
The load temp of the OC'd 1500+ is the same as my 2600+ stock, idle.
Think I should push it some more?
