Athlon shuttle system on a budget
bob
My athlon K7 is getting old and tired. even with 384mb of ram, it still doesnt have the power to get some things done. i went to newegg.com (tigerdirect is more expensive) and searched for a shuttle system under 400$.
I have a GeForce 2 ultra, with 64mb of ram for a video card. It is AGP1X, and i dont know if it will work in an 8X slot.
For a cd drve, i have an LG 52x CDRW wallmart special, which has been working flawlessly for almost 1 year.
Shuttle XPC Barebone System for Socket A at 266/333MHz FSB AMD CPU, Model SK43G
$183.00
Excel Stor 80GB 7200RPM IDE Hard Drive, Model J680, OEM Drive only
$55.00
KINGSTON KVR266X64C25/256 256MB 32x64 PC2100 DDR RAM CL 2.5- OEM
$37.69
AMD Athlon XP 2500+ "Barton", 333 FSB, 512K Cache Processor - OEM
$86.00
Total: 361.69$
i know i could probably knock off 120$ from the price if i used neweggs Cheap-o 15$ case, a 45$ motherboard and my own powersupply. But if i did that, i wouldnt have a miniature case. Or, just get a 200GB drive and use the cheapo case/motherboard.
My videocard isnt any powerhouse, so the HS&F are small. I dont know if the motherboard would be bothered with 1x agp. And would that shuttle handle the Barton core?
The Shuttle will handle the Barton. Since you're on a budget, I'd recommend getting a Sempron and putting the saved cash towards something else (ie: RAM, video card).
You should seriously look at some PC2700 ram, otherwise you'll be doing the Funky Chicken with timings and dividers to get it to run. Your selected PC2100 stuff only runs SPD at 266MHz, not the 333MHz the Barton wants to run at.
As for the video card, 1X slots use a different voltage if I remember. Some old mobos (like my old Asus P2-99B) could take a 4X card in the 1/2X slot. The slots and PCB's are keyed differently, depending on what voltage they require, unless they are using the "universal" key which leaves you guessing.
I don't think that video card will work in an 8X slot. The SK43G does come with integrated graphics, but you can go with something like this if you want more power: http://www.newegg.com/app/ViewProductDesc.asp?description=14-127-115&depa=1
This hard drive is only $7 more and the 8MB of cache really make a difference. It also comes with a 3 year warranty: http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-122&depa=1
You also need PC2700 RAM to match your Athlon XP 2500+ processor (333 FSB). This would be a good choice: http://www.newegg.com/app/ViewProductDesc.asp?description=20-156-001&depa=1
And the SK43G will handle the Barton core just fine.
if you are aiming for under $400 i wouldn't go shuttle.. but let me try
i would get one of these:
$218 http://www.newegg.com/app/viewProductDesc.asp?description=56-101-455&depa=0
or
$263 http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-427&depa=0
or
$264 http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-428&depa=0
but that will put you over budget way quicker..
but if you don't want to save up $$...
$189 http://www.newegg.com/app/viewProductDesc.asp?description=56-101-420&depa=0
$76 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-440&depa=0
$88 http://www.newegg.com/app/ViewProductDesc.asp?description=20-220-001&depa=0
$62 http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-122&depa=0
$415
then run the cpu at something like 166 x 12
put the memory at 2-3-2-5 and you should be set...
get 2 sticks of memory if you are using integrated graphics..
i have no idea what the bios can do on that shuttle though.. i know it would be worth the extra $$ to get a sn41 or sn45 .. because i know they have great options for tweaking the fsb, memory, and multi and all that...
frys and compusa have rebate sales ALL THE TIME for their 160GB - 200GB hdd's. I paid $60 after rebate for my 160GB, maybe search that route for a better hdd and an even cheaper price.
I switched a few things around, including the case to an IDEQ 210V. I dont know much about its bios and motherboard quite yet, but the system price is now just under 300$ :) .
I heard the semptrons were junk for power applications, more better for "office applications" (might as well use a 400mhz celeron if i want to do office applications). That is why i chose the barton. I dont want to need an upgrade for at least 5yrs (my current system has been dragging on 6 years, and it wasnt so hot in 1999).
I would like to be able to use my pci tv tuner card to put 3-stooges or simpsons on dvd, but my current computers hard drive cant keep up with 30fps 640x480 raw video, it can only handle 320x260 @ 20fps. It doesnt have the meat on the processor to compress the video in realtime, it drops a load of frames each time it writes to the drive.
I changed the ram to DDR400 256Mb stick for 37$. I know it will be a big factor for slowing me down, but its cheap and im not really into playing a lot of games.
Biostar iDEQ Barebone System Model IDEQ 210V
$149.00
Western Digital Special Edition 80GB 7200RPM IDE Hard Drive, Model WD800JB OEM
$62.00
Rosewill 184-Pin 256MB DDR PC-3200, Model RW400/256 - Retail
$37.00
$86
Total : 334$
I really wanted that 99$ 200Gb hard drive, but the IDEQ or Shuttle didnt support ATA150. The ATA120 200GB model was around 140$. I dont think i would fill 200Gb very quickly anyways, except for recording video.
I could not find any reveiws on the internet for the IDEQ. For all i know, it doesnt come with printer ports or serial ports. I do have a linux print server/dsl router/VPN server/FTP server/ MP3 streaming server/HTML server/Firewall/Router so i dont need a paralell port.
I dont know if the IDEQ comes with a Heatsink and fan, which i can get one for another 10-15$ (just the heatsink, i have enough fans to last me a long time).
ok.. i have heard that the ideq's are decent.. but... get a mobile barton.. 35 watt too.. even if you don't overclock.. they are 1.35v stock voltage instead of 1.65v which lets them run cooler.. and you can overclock if you wish..
the 2400+ 35watt is the same price as that desktop barton.. ok.. i just checked the price and it is $97.. (i always include the shipping).. get the 2200+ 35 watt.. for $76.. it will be able to hit 1.83 ghz like that 2500+ does.. guarunteed.. i shouldn't say that.. but it really will...
anyways.. go ahead and get what you just listed, except swap that 2500+ for a 2200+ 35watt..
it will save you $10.. which you can save up to get that extra 256mb of ram in the future...
i really don't like using winXP with only 256 mb of ram.. 512 really makes a difference...
but as always.. the biggest savings can be had with the hard drive.. if you look at your sunday paper ads you can always find a good deal, if you live someplace that has a lot of stores to choose from...
however.. if you are really trying to save money, don't get a SFF... get a full size case.. it is more common and therefore more economical...
good luck with your decisions..
also.. celeron vs sempron.. celerons are crap.. except the celeron D.. . but a normal celeron won't get you much.. amd is less crippled by less cache than intel.. my mom has a 1.2 duron and it can do any normal thing better than the 2.4ghz celeron i use at work..
I just need a "budget pc" but without the dell price (4500$ Ultimate gaming machine with a 16x cd rom drive, similar specifications to a 1000$ newegg comp).
The only reason i want the SFF is space. I barely have room for a small ATX tower. I also like to think the case will almost fit inside my cars glovebox.
I read the IDEQ claims to be quieter and have more heat-pumping power. I read reveiws on SFFtech.com and thats what people have been saying. The mobile processor will be a thing to consider for me. My 500mhz Athlon (i think) is rated at 60-something watts. 80W for the barton? I almost always have my computer
i will look into the processors and see if the mobile one has enough power for things i want to do.
Wouldnt the 266Mhz FSB Vs the 333mhz fsb make a difference?
If you go with an AthlonXP-mobile, you will need to go with the iDEQ 200N instead (assuming you want to go with Biostar). The 210V has very limited overclocking features. You cannot change the multiplier or CPU voltage in the 210V, so beware. Some people who bought a 210V + XP-M found out the hard way.
Good forum for iDEQ's: http://forums.sudhian.com/categories.cfm?catid=96&forumid=1
