Athlon 64 X2 O/C'n
nice whats the temp and cooling solution?
also what motherboard if i may ask
Phase Change I'm running -20C give or take right now
DFI NF4-ULTRA SLI-DR
This board is a finicky bitch but really great overall.
I got really excited and then you said phase change :(
I guess us normal pwople will have to just pray really really hard.
Congrats on the OC though!
I killed the board. I think the dual cores at 100% load at 1.5v was too much. I really think the power circuitry in alot of boards will have to be updated for extreme overclocks with these things. I'll probably just run 2.8Ghz for a week burn in on the next board then try and go for a kamikaze run again. On the bright side I've never gotten this BH-5 this far before 263 1:1 is my new record.
Your situation is not unique. Many people, including myself, who are overclocking X2s are finding a larger than normal load on the mosfets. I have a 90mm fan blowing right on the heatsinks, and the PWM is still about 50C-60C load (depending on ambient). And that is only at 2.7GHz @ 1.55V.
My DFI SLI-DR is a soldier though. I wouldn't exactly call it finicky, but having an onboard memory controller on the CPU while you're overclocking it means tweaking a lot more RAM settings than usual if you're running at 1:1 (like I am, with TCCD).
I've had my board at full load for almost a week straight now, while stress testing my overclock. No signs of dying yet.
Yep, these SOB's are loading my Mosfets like crazy. I'm going to have to put 3 BGA ramsinks on my un-heatsinked mosfets since they're hitting close to 50C load.
