SynVisions
- Oct 26, 2005
So I got an Athlon 64 3000+, MSI K8N Neo4 Platinum, and an eVGA 7800 GT - along with 2 x 256 mb and 1 x 512mb Corsair XMS memory from my previous computer. I also have a good thermalright heatsink with a 120mm fan. Anyway, I haven't had much luck overclocking the memory so I decided to start conservative. I went ahead and overclocked my system, left the video card at stock. After some messing around I set it at 290 x 8.5 for a processor speed of 2465MHz, CPU VID at 1.593v, and a 2:3 memory divider with the ram running at 193. When testing just how far I could push the FSB/HTT it seemed to be stable up at 310 so I figured 290 would be safe. The processor seemed to be ok up to about 2.5ish as well. Temps were fine, Prime95 ran for many hours without issue, same goes for memtest86.
Well anyway I started to get problems in games, the only games I play at the time are WoW and Battlefield 2. Basically what happens is every once in a while, the frequency varies quite a bit, the video just locks up but I can still hear the sound going on the background. I also get a decent amount of artificating. I figured the video card must just be bad because I have it running at stock. However when I run my entire system at stock I don't experience any problems, I even tried relaxing my memory timings big time to 2.5-4-4-8, and lowering the overclock quite a bit but that didn't help. Any ideas as to what the problem could be?
