Athlon 64 OC on nForce 3 chipset???
Drag0n_45
Hmm... ok people, I've been reading a lot about what these Athlon 64's can do, so I decided to go out an buy one, and as an upgrade from an XP 2700+ i had to buy a new mobo...specs are listed below. Looking at the bios in this thing im not sur ehow to overclock.. it only rates the cpu freq at 200 MHz, which i know isnt right not only from performance but also from well, common sense. What I am curious about is if any of you know anything about this mobo that would help me push it farther.. im idling at around 29-31C and havent dome a prime95 on it yet so i dont know what im looking at for load. Any help would be great...thanx.
Try these settings in BIOS:
9x multiplier
HT 3x
ram 166mhz
FSB 250mhz
vcore around 1.5 or so
Play with these settings and see what you come up with. Any other questions I'll try to help.
ok.. i checked my bios and i got bad news.. on this chipset for some reason the only settings i get in the bios are (OC=Overclock)
CPU OC in MHz
AGP OC in MHz\
CPU VCore Control
AGP VCore Control
HT-Link VCore Control
DDR VCore Control
so it sucks that ic ant OC....
Press Ctrl + F1 while you're at the BIOS main screen.
Stupid Gigabyte and their "hidden advance uber-1337 [H]4rdk0r3" settings. Psht.
