athlon 64 LE-1620 question
danisimo
Would this processor work with all AM2 motherboards out there. I checked couple motherboards for their CPU support and this one was not listed there. Does that mean it has no support? thanks
it may be that the m/b maker will have to update the bios. check your m/b support site and ask them the question. It will probably work anyway but make sure.
