Athlon 64 FX-55 OC Data
Gr@ftoon
How does the Athlon 64 FX-55 Overclock? and do they have revision? such as winchester,san diego,venice.
I believe that all FX-55s are Clawhammers, someone correct me if I'm wrong.
As for OCing, most of the ones I have seen have achieved pretty nice ones (~3ghz), but of course it all depends on what kind of setup you have.
i believe they will have 90 nm ones fairly soon.. they do oc good like the above poster said, 3ghz is attainable :)
edit, where are you ^ in il?
maybe they will have san diego fx-55's, maybe they won't. it's hard to tell at this point
and.. well the FX's are made for sub-zero. if you get one, make sure you don't skimp on cooling, as it'll limit your oc a lot. i've seen anywhere from 2.8ghz to 3.4ghz on air, and up to 4ghz on phase change (WR actually, credit goes to |RickY| & Pedro Rocha over at XS)
