I've not owned an AMD based system since the KT7-A RAID days. But it's hard to ignore the benchmarks between the two. I've got the system in my sig and I'm a gamer. I'm thinking about switching to an AMD based solution because I can get more for my money right now. PCI-Express Intel setup is too costly right now with DDR II and having to buy a new video card to replace my X800Pro.
PCI-E cards are also in short supply anyway. Besides I can get ALOT more for my money with AMD right now. I also want to get a socket 939 CPU and then when PCI-Express and DDR II come to the AMD platform next year I can hopefully use the CPU I've got at the time to keep the costs down for that upgrade.
So I need recommendations on Motherboards and CPU combos. I'm looking at the Asus AV8. I'm not interested in a cheapo bang for the buck board. AMD boards seem to be reasonable anyway so I want to buy the best one performance and stability wise for the money. I want to get at least an Athlon 64 3400+ and I need a ram recommendation. I like Corsair but I've never used their memory on a AMD system. I am also a overclocker. Only air cooling. I won't go far enough to put water in my machine.
I need to build a second computer so waiting for XXX this or that isn't an option. I need to build a rig for my chick so I'm going to upgrade mine and hand the parts down.
I don't want to spend more than $600 on the Mobo/CPU. Otherwise I'd go Athlon FX. Which is fast but not worth the money IMO.
