Steel Chicken said:only difference is cache right?
smaller cache usually means a slightly higher OC, but every CPU is different
DarkBahamut said:Less caches does tend to mean slightly highers OCs, but only small ammounts at best from what ive seen, and the less cache means you need to overclock more to get the same performance anyway . I'd say get the 4000+.
I just wanted the ability to run 4x512- I didn't get it
maybe because of the extra cache?Kil4Thril said:I WILL say that at 2.5Ghz it "feels" 10x faster than my 3200+ at the same exact other settings (take one out- drop the other in)- the 4000+ runs a lot better
2T typically reduces ram performance about 10%, but i've been noticing something weird going on with my dfi and 2T.. but then again, i managed to get 3120mb/s at 200mhz with tight timings, which is insanely high. i'll have to do more testing at a later date, but for now, 2T reduces performance around 2-3% typically, sometimes less, sometimes moreBudzman said:So would running at 2T gimp you or would it not make much of a difference.
