Athlon 64 3200+ cooling?
Azhreal
Been looking at the Venus12 as opposed to the huge Zalman for obvious reasons... weight, possibly eating a dimm slot, and if the fan dies you're sol. For oc purposes is the Venus 12 the best solution out there? It's hard to judge comparisons when people are using 80mm 60cfm fans on one hsf and then a 30cfm fan on another with the same temps. Obviously the 30cfm heatsink is a better design, but what's out there that's the best for a low <40db fan setup?
