ATA100 vs SATA
Mojo
100mbps vs 150mbps. That's the only difference right? SATA is loads programs 1.5 times quicker, correct?
Originally posted by Snugglebear
No & no, read the sticky on advanced HDD issues.
:eek:
dont you mean As the Disk Spins @ Lost Circuits?
it would take the better part of a year to read all the Advanced HDD Issues thread (and links ) :p
there is effectively no performance difference between the two currently, slight advantages in efficiency (depending on the chipset and HDD) potential advantages to data integrity if implemented properly (see the Caution sticky)
niether a single PATA or SATA HDD can saturate either interface
depending on the HDD being 60 to 30 MB/s Sustained Transfer Rate (600 to 300Mbps just as the interfaces are 1000Mbps\100MB/s and 1500Mbps\150MB/s respectively and those are simply burst rates)
for the quick answer
As the Hard Disc Spins Chapter III: Effective Host Transfer Rates Interface Speed as Basis for Classification
but in truth you should really start at the beginning ;)
