At Psu?
thebro
does any one know where i can buy a cheap at psu? or is there such thing as a adapter i can use? i just bought a barebone computer (P1 100MHz) for 13 bux
your best bet would be to find some local computer junkyard that sells old parts.. I have one near me that I find old part like that... they do trade ins too, so that's always nice..
Drive around for a bit and you might find an old computer on the side of the road. Dumpster diving is another option. If both those options fail, go to a small computer shop and I'm sure they can hook you up for a couple bucks.
