At a brick wall...
Everything in my rig is assembled but I've run into a major problem. The hard drive that I have is a Maxtor ATA and it's got alot of information carried over from my scrapped computer, and I absolutely must use this hard drive. Well in my particular case the hard drive is stored in a small cage at the bottom of the case, quite a ways away from any optical drive. My optical drive also needs an IDE cable, yet my motherboard is a shitty Intel 975x and it's only got one IDE slot.
How do i hook up both my hard drive and dvd drive? Neither have connections for SATA and there's absolutely no way I can slave/master them, as they are at least 15" away from each other. I can't close that gap more than 3 inches.
Looks like a SATA/IDE convert is my only option. Any chance local stores such as Wal-mart carry these??
ilikecake said:
You can probably also buy an adapter to fit a hard drive in a 5.25" CD/DVD drive slot.
Edit: Somthing like this
What you have suggested here really will not help. The OP was needing more IDE channels, not a mounting bracket for a HDD.
You could always pick up some PATA to SATA converters. I caution you that they are expensive. You'll have to get them at a computer specialty store such as Microcenter or Fry's, or whatever equivalent places are in your area.
Are you needing to pull information off this drive or actually use it? The reason why most new motherboards use only one IDE channel is because they figure most people are going to be using SATA drives, and they'll have one or two regular IDE optical drives, and that is sufficient.
RAID support and extra PATA channels are pretty much gone from this current generation of boards.
I STILL dont see the benefit of Sata over IDE... Maybe under a high speed 10krpm drive or something... I think the death of IDE is premature.
Either way, pick up a cheap IDE card... You can get one for practically nothing these days. Get a Raid card and you can help offload some of the read/write overhead from your CPU too.
I figured the motherboard would have alteast 2 raid controllers on it, they just need to be setup first in order to plug whatever it be in them. Thats how my motherboard was.. It was a pain :(!
I'b just get a IDE card. But yeah, SATA is taking over IDE. Mostly for space. You can fit atleast 6 sata ports in the same area as 1 IDE port. Also equals more drive capability onboard for cheap.
Sata Cables are alot tougher to work with than Ide cables though :). They really need to re-invent the Sata Cable...
Just hang the maxtor off the edge while you copy all your data off... or buy an external USB2/firewire enclosure for about <50 bucks and hook it up that way.
a cheap external enclosure is the best way to manage and restore that old IDE data.
