Asus z87 fast/hardware boot question
Miltos2304
Hello guys,
I have a question about the fast boot option on Asus z87 motherboards.
Iam using windows8.1 x64
Priority boot drive Samsung EVO ssd 250gb.
Asus z87-plus
So my times at 17sec from cold boot to log in screen.
If i enable fast boot or fast boot with Hardware fast boot my time are 15-16sec. Thats 1-2 sec diffidence only.
Should i do something else for faster boot? Are those boot times how they should be?
And what on earth is Hardware fast boot? I haven't found any info on this.
Did you do a fresh install of windows 8 with that hardware? UEFI boot can speed things up substantially.
For optimal results you want to install Windows in UEFI boot mode with all fast boot related options on. Things like Secure boot and disabling CSM/legacy support are what you're looking for.
I did. I also have these 2 options. Secure boot and CMS/legacy support.
Is it safe to disable these 2 options? Laso what they do excacly? I dont want to damage my new build :)
If its all newer hardware (and I am sure it is) then they can safely be disabled.
Don't disable secure boot. You disable CSM?legacy though.
If Windows doesn't boot after that you might double check to make sure your video card has a GOP BIOS. You might need to flash it.
Your absolutely right.
I disable CSM and when the pc boot a bios message came up saying that my gtx 570 dont support uefi fast boot ( something like that anw).
Gtx 570 is the only hardware piece i got from my old build.
Iam gonna buy Asus gtx 770 anyway soon.
Yeah and I don't believe 500 series cards support a GOP BIOS so good thing you were already planning to upgrade.
Yes, clean install. Its a new build
Right click the Start button and hit Disk Management. Right click your OS drive and hit properties. Go to Volumes and make sure your partition style is GPT. That is also required for GOP boot when you get your 770 as I recall.
