So, recently I built a new computer and everything was going swimmingly. I overclocked the RAM (among other things) to a stable level and began using it. I had to up the voltage a little on the RAM in order to get it to be stable. Now, at this point, whenever the GPUs are under load the sound will crackle a little in games. The sound crackles even when running a stress test on GPUs and watching Youtube. When there is no load on the GPUs, no crackle. When I dropped the overclock on the RAM the crackle disappeared ... even when the GPUs are running full tilt. So, it seems that the issue is cause from the increased voltage on the RAM. (The RAM need a little voltage even to run the factory overclock ... teaches me for buying Kingston
So, I bought the motherboard open box and before returning it I just want to see if its going to be a problem with all ASUS Z170-a mobos or all mobos in general?
