Asus Z170-A network
  • Thread starter Deleted member 108676
  • Start date
D
Guest
I just built a new system on an Asus Z170-A and it runs and boots fine, and I can surf the internet and everything is snappy. I can even run a speedtest.net and get the results I should be getting. But, if I try and download a driver, like Nvidia or even the Steam installer, the download starts then stops and just downloads at 0kbs.
Anyone seen this before? I installed the NIC drivers from the included disk...and like I said, the internet is zippy as shit...I just can't download files.
I have the same board, but as I have no dvd drive I downloaded direct from Asus and Intel all the drivers onto a usb drive. Maybe try to download the drivers from another computer onto a usb drive.
check your browser settings to be certain that downloads are allowed, and that they go to whatever location/folder you want them to.
also check your router setting to verify if the sites you are trying to download from somehow got blacklisted/not allowed....remember that some (most websites) have multiple domain names that direct you to the exact same site.......www.mommastoystore.com might also be listed under mommastoys.com and toystore.com etc etc......
I have heard of this before but i am a little foggy on a known fix, might be a fresh OS install fixed it.
Out of curiosity does it do it with any browser? Just Microsoft IE or Chome as well? You could get an install file off another pc/flash drive and try that.
