ASUS Xonar Essence ST + Win7 64bit Hell
JohnHenrySolo
Cannot get this card to work properly in Win7 64bit.
I have tried all 5 driver versions...will install, it'll either freeze, bluescreen or work...will reboot and itll either freeze or bluescreen. If it does, I go into safemode and remove the driver and try again.
Half the time win7 installs the driver itself and it doesn't work. Sometimes I will get the driver installed and will set it as my default device and i'll lock up. My onboard sound is disabled in device manager currently.
Was working once, then I crashed and it hasn't worked since after many many reboots/installs...ready to return it and try something else...
What driver version works on win7 64bit?
