Asus Xonar D2X+Logitech Z-5500 users
Delete
I am a bit confused about some settings and am requesting your help. First, I have hooked up the speakers via an optical cable. With that out of the way, I would like to know when you set the "SPDIF Out" drop-down menu in the audio center to "DTS Interactive" are you getting 48/24 like I am or 96/24 when playing a test file that is 24 bit and has a 96000 Hz sample rate. I could have sworn i had seen it work at 96/24 while using DTS Interactive before but I'm not certain. It's only when I recently noticed it was at 48/24 that I thought to myself that I should test it out using the file below.
source for the test file: http://osdir.com/ml/radio.linrad/2006-03/msg00079.html
direct link: http://www.nitehawk.com/w3sz/w3sznoise-3-12-06.zip
Another odd thing I have noticed is that when I use DPL II the output is 48/16... has any one else seen this?
