So my system is in my sig. When i overclock my I7 920 to 3GHZ (on air right now) everything seems fine for about a week. I ran prime95 for 6hrs without any problems. But then, i try to boot it back up from going to sleep and it says overclock failed. I try to redo the OC but it still fails. So after booting back into win 7 a couple of times, I decide to try OC again. And it works with the exact same configuration as before. But then it only last for about a week and then says OC failed.
Since i couldnt sleep last night i stayed up all night and saw that my computer randomly turned on during the night and then went back to sleep. Then when i woke up it the OC failed.
Stuff I have tried so far:
1. Ran mem test on all 3 sticks of ram without any problem
2. Made sure the ram was not being OC
3. ran prime 95 for 6hrs without any problem
4. updated bios to latest
5. Cleared the cmos
BTW i dont know if it matters but i have Win 7 64bit with SP1 installed. I am going to disable the sleep mode and turn on hibernation instead and see if that helps.
Any information or help would be greatly appreciated since I am getting watercooling stuff this weekend to OC higher.
5. Cleared the cmos
