ASUS VBI S96J Questions
jimmer411
Im looking to buy a laptop in the next couple weeks and decided to take the barebones route and build my own, since I have quite a few parts left over from my Toshiba sattelite M35X-149 laptop that recently died.
Ill be buying the laptop from milestonepc.com.
Right Now I have a Celeron-M 1.5Ghz as well as a Pentium-M 1.6, socket 479. Would I be able to use either of these CPUs in this laptop, and just buy a C2D later on, or are the C2D a different socket? Sorry, Im not too familiar with Intel sockets and cpus, and the centrino badging confuses it even further, since so many CPU are centrino.
Are the PCI slots and such the same as well? Like if I wanted to use my current wireless card, as well as keyboard etc...?
Unfortunately, the Celeron M and Pentium M are NOT compatible. The mini pci slot is also different (PCI-E). So your pretty much going to have to buy everything in order to get the notebook up and running. If you have PC2-4200 SO_Dimms you would be able to use them. If your on a tight budget, grab a Celeron Mobile 4XX the 400 series are .65nm and have 1mb of cache, they are single core and don't have speedstep but can be found for very cheap (around 50 bux).
You sure about the Pentuim M and Celeron M incompadiblity? The only reason that I have the Celeron M is because I purchased the Pentium M to upgrade the laptop. Same socket and everything, worked perfect.
So is the mobile C2D socket 478?
Core Duo is different. They have a different pinout configuration. The P-M is a 915 based chipset and the core 2 Duo is based on the 945 chipset. If that is the route you wish to take then you would also need a cpu. Hope this helps.
The S96J is a great barebone notebook, I just built mine last week. You can use Yonah and Merom cores in this notebook. I am running a Celeron M Yonah core from newegg ($53) and will be getting a C2D later on. Check what core each of your CPU's are; if they are not Yonah or Merom then they will not work in this notebook, regardless of the number of pins.
