Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The Killer NIC is pointless, so scrap that out straight away. The Xonar side of it depends on the rest of your setup, what will you be using sound-wise?
Regardless of which, it'd be cheaper to just pick up a Xonar DG separately.
