Well, Im finally back in the PC market after my last build that is almost 5 yrs old now.
P4 2.4
Radeon 9700pro
1g corsair
I plan on buying
Asus T3-M2NC51PV $169
http://www.newegg.com/Product/Product.asp?item=N82E16856110061
AMD Athlon 64 X2 3600+ Brisbane $69
http://www.newegg.com/Product/Product.asp?item=N82E16819103036
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive $53
http://www.newegg.com/Product/Product.asp?item=N82E16822136075
WINTEC AMPX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 $134
http://www.newegg.com/Product/Product.asp?item=N82E16820161030
LITE-ON DVD burner $35
http://www.newegg.com/Product/Product.asp?item=N82E16827106057
My overclocking tendancies are over(Stick a fork in me!) and I basically only play WoW and leave my other gaming to X360 and Wii. My question is, with a 300 watt PSU in this system what type of video card could I upgrade to later on? As you can see by my specs I'm very price oriented and not bleeding edge anymore. I'm Looking forward to the low end 8800's or the low end R600's once they come out. I'm guessing the onboard will do fine with WoW, hoping atleast better then my 9700pro to tide me over until I would like to purchase a new vidcard. Thanks for the help in advance.
P4 2.4
Radeon 9700pro
1g corsair
I plan on buying
