AthlonXP
- Oct 14, 2001
Going to run 2 in SLI, just wondering which setup would you prefer and why?
Does your case have excellent airflow? Strix 980. Seems everyone is genuinely happy with that cooler so far.
No plan to overclock them though, just want cool and quiet running cards.
Seconded. My 970s in SLI barely break 70C under most gaming conditions with default clocks on the default fan curve, which tops out around 42%/1100 RPM at that temperature. Can't hear them at all with my case fans on the lowest setting in an (original) NZXT Phantom. The 980s might run a hair hotter than the 970s, of course.Cool & Quiet = Strix for sure then
Just installed them a few minutes ago. Man they are huge!
If you have this much spacing, the strix would be a good option. If they are sandwiched you should go reference. But as has been mentioned, the strix will dump the hot air into your case so you'll want solid air flow
Thanks, think I will go back to the stock cards then. Anyone interested in one or both of these guys then? Can't return them to Newegg.
Agree with this. I wouldn't jump the gun and return them just yet. It looks to me like you have good airflow in your case. I'm assuming the front fan is intake and the back is exhaust. With a direct line-of-sight to the video cards that front fan should be doing a good job at routing the heat they're dumping into the case out the back.I would run the Asus cards under load and see what kind of temps you get. The asus cards are supposedly higher quality so it would be a shame to let them go, especially at a loss
There is no way its hitting 1500 out of the box. That is not even their top 980 card as there are 3 models ahead of that. They sure as crap would not let a chip like that be in the 4th card from the top.Interested..I have the evga GTX980 SC. It hits 1500 out the box. Let me know.
Out of the box means you did nothing but install the card and it goes to 1500 automatically under load? I do not believe that at all. The cards are rated at mid 1300 mhz boost and NO card has EVER automatically boosted that much higher than its rated boost. EVGA sure as hell would advertise high 1400 rating if it was boosting to 1500 out of box. And again they have THREE other models above that so it makes no sense. Especially since some of the top end cards cant even do 1500 when oced.Both of my $549.99 reference GTX 980s (evga) hit over 1500mhz out of the box. I'd say you should give it a try and see what happens.
I think he just means that the cards were able to hit 1500mhz without any mods or voltage increases
Then people need to say that because out of the box means out of the box not overclocked. I don't know why people cant be clear when making a post.I think he just means that the cards were able to hit 1500mhz without any mods or voltage increases
Okay fine but like a I just said be more clear next time then there wont be issues. Specifically stating "out of the box" means nothing was done.Rinse the sand out and relax. It simply (or should have obviously) meant that nothing special was done and it overclocks pretty well.
Thats some fine logic. So you misuse a word then get an attitude with me? At least if I screwed up I would be man enough to just admit it and move on.Then it would run a the specs stated on the box.
15 minutes are up.
