Asus Striker SB temp .... need advice
White_Hair
Hey guys:
I finally got time to put up my rig. I noticed my SB temp is a bit high (comparing to my previous DFI Opteron built). My system is currently under stock speed and the SB Vcore is set to 1.55V. My temp according to Asus PC Prob is about 53C.
Voltage settings are the follows:
Cpu Vcore: 1.31
Memory Voltage: 2.100v
1.2v HT Voltage: 1.3v
NB Core Voltage: 1.4v
SB Core Voltage: 1.55v
CPU VTT Voltage: 1.4v
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
Is that temp for the SB normal or too high. Cpu temp seems to be around 30C Idle.
Advices will be appreiciated :)
Thanks
