Come get it people:
Asus Striker Extreme: BIOS 0901
Supposedly fixes are as follows (taken from XtremeSystems.org):
Version 0901 2007/02/14 update
Description Striker Extreme Release BIOS 0901
1. Enhance memory compatibility
2. Fixed power Fan can't work after S3
3. Set DDR2 Termination Max default Votlage to 1.25V (Memory Voltage is 2.5V)
4. Add patch to support Creative X-FI sound Card
5. Speed up S3 resume time
6. Change CopyRight year from 2006 to 2007.
7. Fixed memory clock mode option may disappear when SLI ready memory is used
8. Finetune USB driving
9. Fixed FSB 1333Mhz CPU clock incorrect
10.Fixed sometime the CPU VID table will be dystroyed
11.Fixed Vcore error when CMOS checksum fail
12.Fixed summary page "CPU ID/ucode ID" string will show "CPU ID/uc" instead
13.Update EZ-Flash version to B319
14.Fixed SETUP hang on when trying to modify "Internal Connector LED" item under Triditional Chinese mode
15.Finetune H/W Monitor Voltage warning range
16.Fixed system hang when Music Alarm play length is over 1 hour
17.Lock 'F8' and 'DEL' function key when after entered EZFlash
18.Fixed Music Alarm auto shutdown when using Presler 3.4GHz CPU with WD1200 HDD and ASUS DRW1612BL
19.Fixed system may show "error loading operation system" message when using CHS mode PATA HDD, and set "Access Mode" to CHS at the same time
20.Fix system will report error when there is Legacy floppy is disabled at the same time when SATA ODD is the only device connected to this motherboard
21.Enhance HDD compatibility
22.Change Max FSB to 650MHz on AI-Booster
23.Fixed CPR fail when overclock too much
