Mar 2, 2009 #1 B backwoods Limp Gawd Joined Mar 1, 2009 Messages 128 p5k asus i cant set my bios every time it goes into over clock. then when i boot it wont start goes into asus safe start bios. even when i add new hardware it goes into safe boot does all p5k have this error?
Mar 5, 2009 #2 T THUMPer Supreme [H]ardness 2FA Joined May 6, 2008 Messages 4,684 Non stable overclock then maybe. have you flashed the bios?
Mar 5, 2009 #3 B backwoods Limp Gawd Joined Mar 1, 2009 Messages 128 nevor ever ran over clocked yes flashed stock speed
Mar 5, 2009 #4 T THUMPer Supreme [H]ardness 2FA Joined May 6, 2008 Messages 4,684 You mentioned over clock. So i was not sure. Take out a stick of RAM and see if you can boot normally. Switch out the ram sticks
Mar 5, 2009 #5 B backwoods Limp Gawd Joined Mar 1, 2009 Messages 128 stock is what it is set at when evor i put new hadware it overclocks and wont boot some stupid asus thing
Mar 5, 2009 #6 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Have you tried updating your BIOS? It could be an issue with the version you're using.
Mar 6, 2009 #7 B backwoods Limp Gawd Joined Mar 1, 2009 Messages 128 i did update awhile ago there aint too many for this model asus i wil check again
