Asus SLI Premium Voltage Question
Well I am trying to OC my 4400+ so I set the voltage to the max safe value in the bios of 1.4 (going off of the processor max, not the +10% right now) and according to the bios and AsusProbe, I am getting a voltage between 1.328 and 1.344. What is going on here? Is that a read problem or is that an actually undervolting that the Asus board does? It seems that even when I set it to 1.5, it is only about 1.45 or so after that?
i dont really know the answer on that, but can you tell me what overclocks u getting w/ this board right now? are you on air as well?
hopefully some1 here will give you an answer to your question.
My overclock right now is at 225 * 11 (2475 Mhz) with a Thermalright 120 and a Panaflo 120mm. The voltage is at 1.4 in the bios. I am starting slow and testing my way up to see how far I can go without pushing it over 1.4 volts. So far, so good.
I just want to know if i should go by the voltage I set in the bios or the one that is being read by the MB? I don't want to push this chip too hard, even tho I really can't with the Asus board since the voltage only goes up to 1.55. But I already set it up at 1.5 volts and the temps went up about 10 C from where they are now under full load (about 49 right now with the fan turned all the way down using an Aerogate I (5 bucks from svc.com so i couldn't pass it up)! 2-3 degrees cooler if it is pushing 108 cfm on it haha).
that's still good result i guess.. i'm just hoping to get my X2 4400 to 2.6 and i'll be happy camper :)
I think you should always go w/ the bios, not what the hardware monitor results. that's just me and just to be on the safe side. :) good luck and hopefull you can crank that up more
Ok... I was just messing around and I believe I found something in the 1005 bios that needs to be fixed. I decided to raise the voltage to 1.45 in the bios, so i rebooted and changed it, It make NO jump in voltage in windows or the reading in the bios. Next I decided to try 1.475, and it jumped to 1.45 in both! What is the deal?!
It's probably just a bios issue that will be resolved. I wouldn't think 1.45V is going to kill your CPU especially with that XP-120. Granted I'm not running a $600 CPU :cool: . Just because you set the voltage in Bios doesn't mean you're going to get that amount of actual voltage. Generally speaking, the ASUS probe isn't going to completely mislead you on actual voltage. It will give you a ballpark figure on what kind of voltage you're running. I had wacky voltage issues with my K8N Neo4 Plat SLI. It wouldn't give me more than 1.45V no matter what I tried.
