2 questions:
1. If I am running a single videocard on this board (7800 GT), do i have to plug a power cable into the EZ-plug? Should I? Or is EZ Plug only used if running 2 cards?
2. I have an Antec TruPower 480W power supply with a 20 pin power connector. This board requires a 24 pin. Will I be OK if I buy and 20-24 pin adapter and use that? Or do I NEED a new power supply?
THANK YOU FOR YOUR HELP.
