ASUS SLI and NV5
As there seems to be quite a large amount of space between the pcie slots on an nforce 4 sli motherboard by asus (as it has 2 pcie 1x between them), and this is far more space than is on the reference nvidia sli board, would it be possible to fit two nv5 silencers?
or would there simply not be enough space?
also if this was installed could i use the bottom two pci slots (there are only 3 on the motherboard) for two sound cards, or would the cooling be greatly affected?
thanks
f
why two sound cards? :confused:
you wana have some air space for the air to come into the nvsilencer... i think a centimeter should be enough, no matter what your going to have hindered air flow, someone needs to develop a cooler for sli.. i think zalman would probably have the easiest time since they have been doing heat pipes a long time
