Downloading stuff from ASUS is like watching grass grow! It took me 15 minutes to download 6mb of data, and thats normal for their website. I have cable internet too!
Asus' support does suck from what i hear, and the bandwidth is only the tip of the iceberg I'm sure. All Major companies like Asus know better, this is a sign of negligence.
many ftp's are slow lately, due to the high number of connections, brwose directly via an ftp browser eg Flash FXP, it will complete the download at an albeit slow speed...
Have you tried to remove the battery for half a day, put it back in , reset bios then , place jumper back to default setting and try to boot then ?
M2A-VM
first release BIOS v0107
so that should be on ya baord when you bought it
Latest release is 0303 and plz don't flash from within windows !!!
And from what you hear and don't experience yaself plz don't comment on it then, I had 2 good RMA's from Asus without a hickup or questions asked, bios releases can be slow but if you look at the ubernoob questions some peeps ask ,jeez I wouldn't like to be a support member from any mobo maker... it still takes knowledge and research to get a pc working , hence why there are pc shops, not everybody can assemble a pc or get it running or setup correctly.
Take for example a guy who wants to overclock his C2D running at 2400mhz stock but wants to get 3600mhz out of it without altering any voltage. Even at stock the rig wasn't stable , why overclock it in then, find ya culprit first then move on.... He made 20 posts that his board was crap but didn't want to change anything from auto not even for his ram ( that requred 2.3 volts to run according the manufacturers specs and board booted but at 1.8 volts for the ram) His argument : I buy the most expensive board in the world and it can't even run my hardware out of the box, *?*?* is totally crap was his conclusion....
