Asus Silent Square Question
xenithon
Hi all. I have a quick question about the Asus Silent Square cooler (not the Pro version):
1. is it AM2 compatible? I am getting mixed info from different sites - some say only the Pro is, others say the non-Pro is compatible with AM2 too.
Thanks and Cheers,
X
Hi there. Read that list and indeed it says it would work, but a number of reviews such as the Madshrimps review say that only the Pro version comes with the required bracket....and the importers here are a bunch of imbeciles who couldn't tell a CPU from a piece of memory :p
