Asus says my PC is having instability issues...
alnen
I sent them this email:
"Hi,
I own an Asus A7N8X-Deluxe. I am running 2x Corsair XMS 512MB PC3200CPT2
RAM sticks, AMD Athlon XP 2500+ Barton CPU, and a 20 AND 80 GIG Western
Digital hard drive. I am currently running it with an ATI Radeon 9200
video card and Windows 2000 professional. Anyway, here are my symptoms:
Computer seems to have alot of corrupt files. Asus Probe won''t open,
it
says it can''t find the entry in the dll library. After the computer
has
been on for a while, I keep getting errors whenever I try to open
things
(ie, when opening the SEARCH FOR FILES program on the Start menu, it
says
"There was an error opening explorer.exe" These errors seem to be more
common the longer the PC is on.
To try and troubleshoot the problem, I installed Windows on my other HD
to
see if I got the same problems. Well, it gave me trouble just trying to
install windows. It wouldn''t let me install some files, and so I kept
clicking retry until it worked.
I have replaced my power supply, and my video card to fix this problem.
I
also took everything apart and reseated it (including the CPU) all to
no
avail. In the BIOS, it indicates that the CPU and mobo temps are pretty
low (around 30 degrees). What should I do?
Is my mobo faulty or can i somehow fix this? Please let me know as soon
as
possible! This problem has really been a pain, please get back to me
soon!"
They said my problem is a stability issue and is usually caused
by either the memory, power supply or the CPU running too hot.
I replaced the PS with an Antec, and problem persists. I checked my CPU, and it was runnng at 28 degrees. The mobo was at 30. As it stands now, I can't do anything on my PC. I formatted the HD and i could not install Win2k successfully. So I definitely can't get on the net to do a memtest. What's your best guess? This problem didn't come after I did any changes to my PC, hardware or software. I had just left it alone for a few days while out of town, then when I came back, all this started happening. ANY advice would be helpful, I don't know what to do anymore. PLEASE HELP!
Your on the net now.. Get a blank floppy and install memtest86 on it. Put it in your computer, and it shoudl boot off it and test your memory. If the computer wont even make it that far its time to start swapping parts to figure out whats goign on.
On my old box listed below, I got similar stuff using older chipset drivers. I didn't see if you had updated those or not, so it might be worth a check on the Asus site to see if any are available.
and what Frosty_axe said - install MemTest86 to a floppy and keep that sucker handy - it's the first thing I do if my machine starts to act weird.
I didn't know I could do that, cool. Anyway, I'm not sure exactly how to make that floppy. I saw a link on that page's forum that says you need burn a CD then use that to make a floppy. Is there an easier way? Thanks!
I think if you click this link, you'll get the download. Just unzip the sucker and run "install" - be sure you have a floppy handy. If that doesn't work, check out the readme file. It'll make a bootable floppy for you. Simply leave it in the drive, reboot, and it'll run for ya. It takes quite a while to run all of the tests and most folks recommend having it run through the gamut more than once. Just get it going before you go to bed and let it run all night - that oughta test it out pretty well.
Sorry for the long time of silence. The RAM tested bad, I told Corsair, and got my new sticks. It fixed my problem! Thanks for your help!
