Asus Sabertooth Z170 question
Bloatedpig
I am currently gathering my parts for my build and have a question. I have a Sabertooth Z170 Mark 1 MB and I have an older Hard Drive which is not too fast (8-years old) and plan on using a WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache as my primary drive. Which of the SATA ports do I hook up each for optimum performance and compatibility? From Left to Right there are 2-tan, 2-black and 6-grey ports. The owners manual is not too clear on the hookup.
thanks!
The gray ports are for the Intel Z170 chipset. They should be numbered, just start with the lowest one.
The beige are the ASMedia chipset.
The black are likely the SATA express ports.
Just going by the specs, I didn't feel like downloading the manual.
It's a hard drive, not a SSD. You'll get the same (bad) performance no matter where you connect it. It could be on a SATA2 port and it wouldn't matter.
Tru dat ^^
However, since you are going with a new Z170 rig, I would strongly recommend you invest in an pcie/nvme m2 drive to boot from, and use that 1TB WD for storage and backup. Just remember that you will lose 2 of your chipset's sata ports in the process (check the manual for which ones), so just be sure to connect the WD to one of the 4 remaining ports.
This way you will get all of the advantages the new MB has to offer in terms of speeeed :)
Thanks for the reply. Bad performance is all in how you look at it. I've had 2-friend's ssds go bad on them in the last year and they are still very expensive per GB at the moment. Not ready to make that same mistake with my new system.
regards,
Tru dat ^^
Thanks bonehead...I'll have to look into that....thanks
I purchased a Crucial SSD M.2 Crucial MX200 500GB M.2 Type 2280 (Single Sided) Internal SSD. (PCIE is too expensive).....Which 2- sata ports would the internal M.2 take? Are there specific ports or which ever is open?
regards,
I'm still using a Samsung 830 pro in my system
among other newer Samsung ssd's
Never a hitch
And the 830 is kind of old now
Still going strong
Ssd's are extremely reliable now. Use a nvme pci-e ssd for boot and everything else for storage.
I have samsung 950 pro as my boot drive, it is amazingly fast. And they aren't too much more than SATA based ssd's
The M.2 drive uses the M.2 socket, but it disables two of the standard ports. The ports which are disabled should be noted in the User Manual.
How did you not want to use an SSD (which have been around for a couple of years now) for reliability reasons, and then jump on M.2 which is still new?
M.2 is just a SSD in a different form-factor that teams two SATA channels, it's not anything untested or unreliable because it's "still new" as you suggest here.
"newer" than a standard SSD, and using a socket which is a much newer addition to the motherboard chipset. And yes, it's the same, so if he doesn't trust a standard SSD, why jump on M.2? I'm sure you understand the point that I was making.
^^Partially correct^^
That drive is the same as a regular SATA SSD, but built on the m2 form factor with an "M" keyed connector. It will only take bandwidth from 1 of the SATA ports, unlike pcie/nvme which will take 2 as stated before.
You should check to be certain that your board's m2 slots will accept the "M" keyed drive, most of the newer boards do not.
As for which slots get disabled & the key types, you WILL need to download the manual to be certain :)
And for the record, before I switched to nvme, I had several regular SSD's that were 2, 3, and 4 years old and still going strong to this day nottaproblemo :
