MiG29TangentBoy
- Nov 2, 2004
One of my colleagues has recently upgraded his gaming rig (990X with latest BIOS, FX-8150, 16 GB GSkill Sniper memory, EVGA 550 Ti, Antec Earthwatts 850 watt psu), and it has a very peculiar problem: the VDDA voltage slowly drops over time until the system shuts down. It starts off at 2.5 volts, but goes down upon system stress tests (mostly OCCT)...the Asus monitoring software pops up a warning when it gets to about 2.2 or so, and once it gets to 2.0 it craps out. I'm rusty with the newest AMD stuff, so I'm not sure what to check/modify in the BIOS to resolve it. System is stock for everything, no OC. I set the VDDA and NB volts up a bit, didn't seem to matter. Temperatures do not appear to be an issue.
Swapped in a Silverstone 750 watt, does the same thing. But I wonder...should this system have a power supply with a single huge 12 volt rail instead? The Antec has four rails @20, and the Silverstone has four rails @18. My only other theory is that the board is somehow defective. Anyone with insight into this would be greatly appreciated. Thanks!
