Asus Sabertooth 990FX - Sluggish
iced00d
Good morning. Over the past weekend, I needed to upgrade my current motherboard - ASUS M4A89GTD PRO/USB3 - with an SLI compatiable one. After doing some reasearch, I decided to go with the Asus Sabertooth. Not only because of the SLI features I needed, but because of the OC rating. After ripping my watercooling system apart and mounting the board, and reassembling everything, I found out that I had to do a fresh install of Windows 7 (Ultimate x64) . TG I had a backup of my system before hand After loading windows and ALL of the patches, I installed all the drivers from the CD and even checked the web page for bios and or system driver updates which I did.
The problem that I'm running into now, is windows seems very sluggish when loading. What use to be a couple of minutes from pushing the start button to loading windows and all of the initial startup files, now seems to be taking almost 7mins to just load. Thinking it was my hard drive I cloned the drive but have the same problem. I've checked the bios and have even set it back to the defaults (except for the fan options seeing that I don't have any) and I get the same problem. I eventually want to get this puppy up and running and even try out some OCing if I ever get that far. If not looks like an RMA and back to HyperSLI & M4A89GTD again >.< , which I'd hate to do. Thanks in advance...
System -
* Asus Sabertooth 990FX (current bios)
* AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
* 16GB RAM - (2x) G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3- 12800CL9D-8GBRL
* Seagate Barracuda 7200.11 1.5TB SATA drive
Have you turned off all of your startup items in Windows? I kind of doubt the problem is the hardware, especially if you used a different drive.
Also, Windows links itself to whatever mobo you are using, and unless you have the exact same chipset, 9 out of 10 times you will have to do a clean install. It's just the way the drivers are loaded when the OS is installed.
Yes, you do have fan options, they are under the advanced UEFI, not the basic. Switch it so you can see all of the options.
Make sure you use the older bios on the website as the newer ones 0705+ are strictly optimized for Bulldozer. You can use them but your PC will run a ton better with the older ones.
