ASUS RT-N10P as a wireless repeater?
DarkDubzs
On Newegg, i can get the Asus RT-N10P for only $10. I know its not really great, but for $10, why not? I intend to use it as a wireless repeater, since i just added an access point with a better router. Is it possible to use this asus router as a wireless repeater, like with no ethernet cable connected to it? I know the cons of having it as a repeater, like it halves the bandwidth, but i just wanna have it get some signal where there is none, like maybe my backyard. So, is this possible? Is there an option to set it as a wireless repeater? Please help, and thanks in advance!
FULL LIST: http://promotions.newegg.com/NEemai...-_-Under50&et_cid=9135&et_rid=4290754#Under50
Hi,
According to specs which I have RT-N10P has a repeater mode. It won't be breaking any speed records but it should give you wider wifi coverage.
Hi,
Would you also happen to know if it can be flashed with DD-WRT?
