You will need not only PCU but good and big case to manage heat from the heater, ops the cards![]()
Pain to produce for somebody who makes bulk cards but for somebody doing small batch it’s not much of a hassle. Those short boards let them do some things that may have allowed for improved power efficiency or cooling. But I certainly see now why the FE cards have such an expensive cooler.I can see why it isn't offered to AIB as it is added to cost to them since it looks like a pain in the ass to produce.
Modding a vbios is not terribly difficult. High end gpus also generally give you quite a bit of wiggle room concerning tdp as well as core voltage. If it turns out to be worthwhile a nice easy to use tool will pop up on the internet pretty shortlyYou cannot set them to "whatever you feel like". Every BIOS has a max power and core limit. Outside of using a modified BIOS there is a hard power limit on every GPU.
I did get costs on the NVIDIA FE heatsinks and that system is NOT cheap at all. It is the most expensive one ever made for a video card to my knowledge.Pain to produce for somebody who makes bulk cards but for somebody doing small batch it’s not much of a hassle. Those short boards let them do some things that may have allowed for improved power efficiency or cooling. But I certainly see now why the FE cards have such an expensive cooler.
Well yeah but in addition to being a whole new design they are also a small batch so custom work. That always makes it expensive. But I think it was a good trade, more efficient board probably cheaper overall too, moved the cost to the cooling but if the format takes off then coolers will come down in price as more people build with them. I look forward to what water cooling blocks become available for them should be awesome.I did get costs on the NVIDIA FE heatsinks and that system is NOT cheap at all. It is the most expensive one ever made for a video card to my knowledge.
Not only expensive cooler but based on igorsLAB info, both FE 3080 and 3090 have 12 pcb layers and uses the backdrill method for amps, that just added cost right there. If I was an AIB partner, if I can get away with a cheaper method, I will use the cheaper method.Pain to produce for somebody who makes bulk cards but for somebody doing small batch it’s not much of a hassle. Those short boards let them do some things that may have allowed for improved power efficiency or cooling. But I certainly see now why the FE cards have such an expensive cooler.
Good to know. I would assume its still possible to grab the vbios off a overclocking oriented card (provided they share the same memory) flash it and have all the headroom you would ever want for the arch.Since 10xx series, the bios has been encrypted to prevent modding.
All thats been possible is use the bios from another card.
Changes to a bios have not been possible.
Well it moved costs.... overall the price remains about the same but if the format takes off than the more people doing it the cheaper it becomes. So it has the possibility to reduce costs over time if they can get their partners onboard with the new format.Not only expensive cooler but based on igorsLAB info, both FE 3080 and 3090 have 12 pcb layers and uses the backdrill method for amps, that just added cost right there. If I was an AIB partner, if I can get away with a cheaper method, I will use the cheaper method.
Dunno. NVIDIA ain't sending me shit, and I have not gone out of my way to procure one of those.The next question is, was it worth it?
