Asus Rampage III Formula Audio Software
Looking for some input from anyone who might own the same mobo.
I installed the newest Realtek audio driver and then I installed the Creative Sound Blaster console software, both from asus.com. When I launch the console, it pops up a message saying:
"The current selected audio device is not supported by the application. Do you want to select another audio device now?"
I click yes and choose "Realtek High Definition Audio", click OK, and it says:
"There are no supported audio device available. You need to close the application."
What gives? This software is supposed to work with this mobo.
Thanks for the help!
