Asus Rampage Dual Boot Problem
roberta
In XP my 3.3 Wolfdale processer works fine at stock and overclocks great using the AI Suite it couldn't be easier and everything shows up like its suppose to
Problem is when I dualboot into Vista I lose overclocking and processer with cpuz shows it running at 2.4 not even at stock speeds, benchmarking confirms this
Installed AI Suite on Vista and it shows the tweaks but not the speed
Flashed briefly at overclock and then it underclocks
I'm thinking wtf is going on here!
Any imput would be helpful
Follow up:
The processer is reconized in Vista device manager and at the rating display as the correct type and speed
Cpuz and AI overclock software its not go figure
It feels ok but dam, do all benches run slower in Vista than XP?
Thanks
Roberta,
As I was reading your post, it occured to me that on the Rampage Extreme you have two bios chips. So you have the option to set up two different 'profiles' so to speak. I think you might have to flash to the second bios and set it up for vista and the other one for XP. Have not thought it out, but I think this would work. Let me know if it works.:confused:
I got the Rampage Formula version need to pullout the old users guide, that could be it
Thanks for the heads up
Will follow up with post reply
Thanks
