Asus Rampage 2 Extreme Question
lego31
Hello All,
I recently just purchased this mobo, and was looking through the instruction manual at "Qualified Vendor Lists" for RAM. Mushkin was NOT one of them listed. However, along with the mobo, I purchased 6 gigs of Mushkin DDR3 ram.
Question: Will this ram work? Or Will i need to return it?
Thank you for your time and help.
-Steven
I can't say for certain, but it is likely that the RAM will still work. Just because it isn't certified/tested with the board it doesn't mean it won't work.
After you get the RAM I would try to identify if there are any problems with it right away, so that you can quickly RMA it. I'd run Prime95 for a day or two, and maybe some memory diagnostics.
Good luck. ;)
Forgot to mention, when you're doing the tests make sure you're using optimal/default timings and not doing any overclocking. Otherwise it could just be the overclocking that is causing any problems.
I assume you knew this though... :D
