ASUS PC Probe II Reporting Bizarre Numbers
/>sycron
PC Probe II v 1.00.43, installed after swapping an A-bit AV8 AGP board for the ASUS A8N32-SLi Deluxe. After opening the app I noticed that none of the monitors were even close to being accurate. Numbers reported look similar to this:
CPU 33C / 45C / 51C / 60C and then back to 33C
MB 36C / 45C /54C / 63C and then back to 36C
CPU fan rpm 8340 / 7080 / 7440 / max fan rpm is 2400? wtf?
Chassis fan rpm 8584 / 7140 / 7500 / Any faster and my desktop will take off!
Does anyone know what might be causing something like this to happen? BIOS is reporting an accurate CPU temperature that doesn't fluctuate but ASUS' PC Probe Tool in windows does not. Suggestions would be great.
Current System:
Athlon 64 3800+ Newcastle w/120mm Fan
Scythe Ninja SCNJ-1000
EVGA 7800GT
1GB Gail Ultra-X DDR400
Western Digital Raptor 74GB
Try seeing if a newer version of ASUSProbeII is available. I've got V1.01.05 running on two systems and the reporting is rock solid (that is, doesn't bounce around and seems to be reporting accurately enough for me).
yeah 7K to 8K seems about right for fan speeds... You are running those fans with the power of the espers right? I'm sure Rydia would be pleased...
