Asus PC PROBE II accurate?
Bloodgod42
Hi,
I recently purchased a A8N32-SLI and a AMD64 4000+. I have been using the mobo supplied utility to monitor CPU temps and they seem a bit high. 45c idle at stock. :(
I was just wondering if there is a chance the temps being reported by the board are off?
Thanks for any input,
Bloodgod42
I use probe too, and it seems accurate. I had high 40s low-mid 50s from idle to load too (with my X2) and I installed a zalman 9500. Long story short: idle temps are now mid 30s, and I have yet to see 44 at load. In addition, my case, the X-navigator, has two hardwired temp monitors that one can place anywhere to record temps. They only confirm the temps.
Too bad PC Probe doesn't let you set the threshold for the CPU fan below 800 RPM. My CPU fan is usually closer to 600 RPM when I'm doing normal day to day stuff.
Can you guyts help explain things to me?
Ne build, a8n-premium x2 4400, no OC, Stock heatsink (which I heard is good enough) my fan for it is running at 2900rpm CPU temp at 29-30, MB at 33 chasis fan at 1600.
Is this normal?
Explain threshold to me?
N I meant normal as to the RPM of the CPU fan, too noisy. what are my choices? turning it down? replace fan only or get the "cooler" heatsink which I have been reading about?
Do I ENABLE q-fan in the Bios? I have heard some peolpe say NO!
turn it down
