Asus PB287q thoughts and need help
vmsx
Some brief thoughts on this monitor, which I've been using a few days.
Coming from the venerable HP ZR30W (30" IPS 2560x1600) there's a distinct downgrade with the TN panel. As much as official review sites say it's a good TN panel, if you're using a HQ IPS monitor, you will notice it and it'll probably bug you. (However, once absorbed in stuff, I don't really notice this detraction.)
Sitting straight on and with a web page open down the screen, greys and blues are distinctly different hues from top and bottom - even 2/3rd the way down.
I've Chrome set at 110% for comfort.
Still, the trade off of price and having 3840x2160 on one panel is still worth it, for me, as I like lots of windows open with small text.
I am having a one nettlesome problem and I'm keen for feedback from any other PB287q users - when the monitor goes off via the OS or the front button, it will not turn back up. (I can bring up the monitor OSD.) The Displayport signal is lost and the only way to make the monitor work again is to hard reset my computer. I have to leave the monitor on all day and then power off my computer at the end of the day.
I am using Linux Mint with the official Nvidia drivers (same with X.org drivers). Geforce 6600 card. I had no such issues with the ZR30w with identical displayport use.
Any feedback from Windows or other users on this issue appreciated. (Do you have proper screen off - on behavior?)
I just received mine today, no problems yet. I am using Windows 8.1 though (moved from 7 specifically for display scaling this week). I set scaling to 200%, enabled hiDPI hack for chrome through the registry and it looks amazing to me. The colors are not IPS good, but I can't detect any backlight problems or gradient issues like you noticed in yours. Mine does however do the dreaded *pop* and blank out for a second about 5 minutes after you power it on, but it seems that turning the brightness down to 50 has mitigated this as I have not seen it since.
Obviously some text on other programs look bad, but I can deal with that as an early adopter. Also, having a hard time getting my mouse sensitivity ironed out because the panel size is roughly the same as my old one but 4x the resolution.
LigTasm
So your monitor goes into sleep mode and then comes back on normally when you e.g., move the mouse or press a key? What video card do you have? My main problem is that when my monitor goes into sleep (or if I just turn if off with the power button), if never regains signal. I have to reset my computer.
As far as the gradient issue. If you take a page like news.google.com and you extend the webpage to from top to bottom, you don't notice the headlines (which are blue) being more blue at the top and more of a washed out blue at the bottom?
I have no backlight problems and I don't have any pop/blank out behaviors you mention. Just for reference.
Other feedback from new pb287q owners welcome.
I do not use sleep mode at all, nor do I allow my monitor to sleep using the power control options. If I walk away I usually turn it off, this is just a personal preference. I can try it and see though.
I notice no color gradient issue on that page you stated, but I am using an R7 260X at the moment until my R9 290 comes back from RMA. I know Nvidia has color issues with DisplayPort and HDMI, but I'm not sure if those apply to Linux. Does the 6600 you have support DP 1.2? Or are you stuck at 30hz?
The pop issue seems to be hit or miss, several people are complaining of it already as well as the right side of the screen going crazy for a few seconds and then stabilizing, as well as black screens with Nvidia drivers. That is another good point, the Nvidia drivers that have been released recently seem to have an issue with SST monitors, what version are you using?
Feedback on sleep mode would be appreciated. The fact that you can physically turn the monitor off and then get a screen is what I cannot do; I lose signal, but I cannot pinpoint why.
The 6600 does support DP 1.2, so I am at 60hz.
I am using Linux driver Nvidia-331 (331.38-0ubuntu7).
I'll check more on DP color issues - I didn't notice anything on my ZR30w, using same hardware and software.
Edit: I notice that Windows Nvidia drivers 337.88 explicitly claim WHQL 4K SST support. Linux is behind, as it's still at 331.x right now.
Ok, I slept just the monitor and the whole PC and had no problem with it waking up. That may be related to the older drivers you have, or the card itself. Not really sure.
Another thing I notice is that the top part of the monitor is relatively darker than the bottom, under all settings and when viewed from all vertical positions (even when monitor is looked at straight on center). I think this accounts for the color shifting.
Using this: http://tft.vanity.dk/monitorTest_scale.html
See other monitor tests at: tft.vanity.dk
I cannot see the 0% to 3% bars when the window is at the top of the screen, but I can see it when placed at the bottom of the screen.
The greater brightness toward the bottom direction is what creates the "washed out" effect.
Do you see these types of things?
Mine does not do that, to my eyes at least it looks perfectly uniform from top to bottom. Do you have another machine you can test with? Your screen might be bad, but it is hard to say without a second rig to test with.
Bad color uniformity is a feature of these tn panels. Nothing new. If you wanted to have accurate color reproduction you shouldnt have bought a tn monitor.
I used HDMI from my laptop (30hz) with Windows 8. Same effect - the top of the screen is darker than the bottom and this to me accounts for the washed out effect on many colors (top is bolder/brighter vs bottom). While not extreme, it's noticeable when looking at it conscientiously. I'm not sure if this is just a TN type issue or my panel having bad brightness uniformity.
Its your panel then. I haven't noticed anyone else complaining of a similar issue on other forums that have owners threads yet.
NV Linux drivers with full SST support are in process now. Please test the monitor on another system for the washed out effect. I have the same effect although not as pronounced as you state with Kubuntu. No issues on Windows or OS/X.
I just returned my 260X for a GTX 660 and I no longer have any problems with the display. I can see my POST screen and enter BIOS under DP1.2 which I could not with the AMD card, also no more screen blanking or popping sounds and the right side does not checkerboard like it did before. It seems the Nvidia card might be better at handling DP1.2 output than the AMD.
Can your PB287q under Kubuntu go into sleep mode and then turn back on? Which video card do you have and which driver, if so?
331.79 with a 750Ti, and it will resume from sleep maybe once in four times during testing. NV is readying another driver release but I do not have a date yet.
Yeah, I'm seeing some similar issues with my PB287Q. While color uniformity and brightness seem ok, the monitor will frequently not regain signal after power-saving features power it off. I also get the pop issues. It's pretty rare, but occasionally I hear the pop with no visual indication, and sometimes the pop is accompanied by the screen going blank for a second or two.
Another issue I've discovered is that several games that launch at 1080p by default or games that I attempt to switch to 1080p for performance reasons will cause the monitor to go blank for several seconds, then the image will return, but I've been dumped to the desktop with the game executable running in the background. Attempts to task-swap back to the game cause the behavior to repeat either indefinitely or until the game crashes.
For reference, this is on an up-to-date Windows 8.1 64-bit system with a GeForce 780 Ti. Monitor is running at 60Hz with Displayport 1.2. nVidia drivers 337.88.
Quick update. Installed nVidia's current beta driver (340.43) and the resolution switching issues appear to have gone away. Will report back if switching to this driver appears to have solved the power-saving issue.
I decided to send mine back. I don't know if the brightness/color problems are just TN panel or a flaw.
I'm definitely going to wait until I can see models in person at a store. There are at least 3 or 4 other named brand companies coming out with units that use this same panel (Lenovo, Monoprice, Acer, etc.), so I expect they'll be at least $100 cheaper in a few months. Even better, there may be sub $1000 IPS-type panels later this year.
Hey vmsx! I am glad that I found this thread, as after owning the PB287Q for roughly a few weeks, I have experienced the *exact* same power savings issues as yourself. That is to say, the monitor will (randomly) not wake up after the PC resumes from sleep, or if the monitor goes into standby.
Sometimes I am lucky, and it will come back if I am patient (~30s), but most times it does not, and I've found that unplugging the monitor power cable, then waiting until the capacitors drain (you'll notice that the orange light stays on for a few seconds after cutting power), then plugging it back in will allow it to regain a signal.
I am running dual R9 280x's in Crossfire under Windows 8.1 (DP 1.2 @ 60hz), so I am not sure if it's the video card, as you noted that you own an nVidia. I am now downloading the Catalyst 14.6 beta drivers in hopes that this may alleviate the problem, but it SURE is annoying.
On a side note, I have not experienced any other problems with the monitor (brightness/colour/etc.). Since it is a TN panel, I have it on a VESA monitor arm, configured to be straight in front of my eyes. This might be why I haven't noticed any colour variation from top to bottom.
If anyone else is experiencing this issue, please let us know if/how you were able to fix it, or simply reply to "+1" the issue. Sure, this is a first-gen SST 4K monitor, but it is a very frustrating problem that sours what would be a blissful experience with this display.
Hope we can get to the bottom of it somehow!
Must just be me, but I love my PB287q (for the price at the current time it's a super monitor I think).
I have it wall mounted so my eyes are about 1/3 of the way from the top and I find very little (for TN) shift laterally (takes an extreme shift to see color change). There is more shift if I bend my knees and go down a foot or so, but it's a TN, so expected.
For a TN I think it's pretty great actually. And the 4k - My oh my. You just can't go back. On the Mac side it's a DREAM and it's very workable on Windows 8.1
I wonder if people are either setting expectations too high for TN and/or perhaps some got bad copies?
This is a great monitor to hold me over until that Asus 32" 4K comes along later (but still need to see a price well South of $1500 to be interesting)
So I bought LigTasm's PB287Q, and while it is a great monitor I don't think i'm quite ready for 4K.
Not sure what is different about my setup from his, but the monitor definitely exhibits the pop issue and I definitely see the TN shift.
I am using the included stand and have it at the highest height setting. That puts my eyes at roughly the middle of the monitor from where I am sitting.
I am using a GTX770 4GB over DP 1.2 with the included cable if anyone is curious of the setup.
I'll be going back to a nice 30" WQXGA screen (Dell U3011/U3014) when I can offload this.
I have the same issues with this monitor, it's extremely annoying, after shutdown it says no signal on displayport, then I need to power cycle it to detect the connection again, often the powerbutton doesn't work anymore at that time.
Also, and this is less annoying, sometimes an audible click and the screen goes black, after about 5 minutes after turning it on ...
To me it feels like a product that just isn't there yet ...
