Captjohnny
- Feb 2, 2013
Wondering if someone can be so kinf as to help me out...
I just received a new Asus PA246 and went to calibrate using the Colormunki Display by XRite...
I calibrated in User mode and it came out fine... issue is, when I disconnect my MacBook Pro and/or reboot, the monitor reverts back to factory setting and I have to go into the System Preferences menu and select the profile. Is there a way to load it into the monitor user settings permanently?
Also the first few times I loaded the profile it booted with a green color cast which I believe I read was a bug issue
Thank you in advance for the help!!!
Johnny
Johnny
