Asus P8Z77-V Deluxe issues
rgraze911
Well not sure what to think but my system has been unstable lately. I would come back to the computer after awhile and find the USB ports dead and monitors off but system still on. Then I would find the system on the repair startup screen or sometimes I would see my OC has failed. I have a core i7 @ 4.63 when I initually set it up and ran the usual tests ie; cinebench, intel burn all were fine no crashes. Has been running fine for about 2 months. I even dropped my oc to 4.5 then the computer would randomly shut down and restart very often then I put my origianl OC back it stays on then. Recently I came back to a completely dead computer pwr switch did nothing. I had to d/c the atx power to mother then it came on but now my windows install is hosed and runs super slow. Any suggestions on what to do next?
Can you post more settings and specific specs (CPU, motherboard, RAM, drives etc)? Also UEFI settings for your OC, the voltages etc.
How long did you run IBT for? Did you try Prime95?
More specs,
I have since put CPU settings back to stock previously bc45, bus 103.0, voltage 1.35
Core i7 3770k
Corsair H100
Caorsair 1200 PSU
16 g DDR3 1600 ram @ 1648
OCZ Agility 3 256
EVGA 4G GTX 680 FTW+ only setting changed is power is at 100
Creative XFI Fatality
I also ran Prime 95 with no issues
Im going to have to reinstall windows since the system is slow now. Just took 10min for chrome to open.
Hmm. So I tried to reinstall windows and the system just hung up an the point where it asks you to install windows. Shut it down then I stuck in my Imation M-Class 128 ssd that I had running win8 and it booted and ran rather quickly. Could I be having an issue with my OCZ Agility3? Just mind bogling.
Return the system to stock and see if it is stable there. Sounds like instability to me. Stress test tools don't catch all types of instability.
Update your SSDs to the latest firmware also.
Well no matter what I tried I could not update the SSD firmware. Using OCZ tool box, I tried connecting it to another computer w/ AHCI enabled, I tried the linux update tool, Either, device not supported, found, or download failed errors. I did find that my secondary drive a seagate 1TB had failed short and long dst tests. Of Course after I reinstalled windows.
