ASUS P8P67 pro still giving boot problems
irneb
I've gone through several threads trying to establish what's going on with mine. I've tried several of the "solutions" including installing the latest update of the bios (which in my case is impossible to do).
The scenario: A couple of months back I adjusted the partitions on my HDD to install Ubuntu in a dual-boot together with the existing Win7 Pro 64bit. After doing this using Windows' storage manager, the reboot failed. It would simply NOT boot from the HDD.
The bootup logo screen shows, then the HDD check (stating no HDDs found). There's one beep (as "usual" ... I think) then the bootup logo reappears and it just sits there. Pressing the Del simply starts the same process again - doesn't go into the Bios setup.
Now I got it "fixed" by inserting my Win7 disc and booting from that. Fortunately it seems that the boot-order did still allow for such, otherwise I don't know what I should have done. After re-installing Win it ran perfectly fine ... until 2 days ago. Again I've adjusted the partitions. Actually I simply created a new partition in the last unpartitioned space.
Again the same scenario. Only this time it doesn't allow me to boot from CD/DVD anymore. I've opened the box and disconnected the SATA cabele from the HDD. Then it boots properly onto the DVD (though this is now useless since where can I install onto a non-conected disc?). But also the Del actually opened the Bios. So I tried the various "solutions" as much as I could.
Nothing allowed me to boot while having the HDD connected, so no way of figuring out how to get the system up and running. Though now there's a bigger problem: It's just started to not even try to boot anymore. The red LEDs flash in turn then the one next to the video card just stays on. The screen doesn't show anything at all - i.e. no data through cable. And also my USB keyboard seems to get no power as its LED's are still off.
So my question: Anyone have any idea what I could do to "fix" this?
Here's my specs:
  • Power supply 850W
  • i7-2600, with standard heatsink & fan
  • ASUS P8P67 Pro
  • RAM: 16GB 1600MHz with heat spreaders (4x 4GB)
  • Graphics: nVidia, GeForce GT 430 - 1GB
  • HDD: Seagate Barracuda 7200.12 1TB
  • Internal 5 in 1 Memory Card reader
  • Liteon 24x Dual Layer DVD +/- writer
A further think which "might" throw some light (though I rather think it is a windows problem): I've constantly had an issue where if I worked on a file from a USB HDD the HDD would turn off after 30-60min. So when I try to save the file I've been working on it takes about a minute for the USB HDD to wake up again ... sometimes this "crashes" the program as it's hanging while the waiting process occurred.
OK I've given up the ghost! Anyone recommend a good robust replacement MB instead of this absolutely CR@P thing?
I don't want to re-buy all the other stuff, just the MB. And of course don't want something which costs a fortune. :D
its either a psu problem or the M/B - do you have a spare power supply that you could swap out?
Thanks for the advise. Though I've now replaced the MB with a ASUS P8Z68-V and it's working fine.
