ASUS P8P67 Pro Query
OmMeE
Hey guys,
I recently bought a P8P67 PRO and hooked it up with a WD 5002AALX which happens to be a 6gbps HDD.
I usually have a dual boot setup (Windows 7 + Win XP Pro).
I installed Windows 7 with no issues on this board with AHCI enabled in the BIOS. However, im trying to install Windows XP pro with AHCI enabled but so far have failed on every attempt.
I've tried, Slipstream method, Switching from IDE to ACHI method, all invain.
Could anyone please guide me how to install XP on P8P67 PRO WITH AHCI ENABLED IN BIOS
Thank you in advance
Tried the same thing. Did the slipstream insertion of SATA drivers, bought a USB FDD & tried the F6 driver insert during the start of the install. The floppy wasn't recognized, there's supposedly a list of 5 specific FDDs that will be recognized by a "virgin" install of XP, but I couldn't find them anywhere. Multiple tries with everything like this. Never worked, always the BSOD during the install. Found something on a forum with some super long registry entries/editing - decided against going there.
Please advise if you find a way to do this. For now I am just switching from AHCI to IDE in the BIOS during startup. A bit of a pain but still pretty quick. I have this on my desktop rig and a laptop, The desktop is dual-boot Win7 & XP, the laptop is triple-boot with Win 7 & Hackintosh having to be in AHCI (or "Enhanced") mode, XP has to be in IDE (or "Compatible") mode.
Install XP PRO first then Windows 7. Windows installation for dual booting or multi-booting should be done in order of release.
Load drivers through USB if possible or use your FDD to load XP drivers for XP Pro installation then, install Windows 7 last!
What we're both (I think) saying is that we haven't found a way to get XP to load in anything other than "IDE" or "Compatible" instead of "AHCI" or "Enhanced" for the SATA configuration in the BIOS. Whether it was loaded first or not. I have tried the slipstream, USB & FDD methods (without being able to find a FDD that is recognized during the F6-insert additional drivers option at the start of the install).
If you do load XP while in "IDE" or "Compatible" mode you are then absolutely, positively able to load Win 7 without changing the BIOS settings to "AHCI" or "Enhanced". It works very well, EXCEPT when you do that you will not have the full SATA capability and/or RAID. There's a lot of dispute about the significance of the difference but when you load WIN 7 that way you are essentially operating your HDDs at PATA/IDE speeds. Whether you would notice the difference between that and SATA/AHCI speeds is debatable. If you do load Win 7 that way, in "IDE" or "Compatible" mode and then try to start up in "AHCI" or "Enhanced" mode you will get a BSOD.
Man, i've been doing this since 2 days now but all the slipstream methods, IDE to AHCI switching method AFTER installation of XP has failed... Still looking. If I some how find a way, i'll let you know :)
Thanks.
TimKLL - Could you please link me to the forum with the super long registry entries/editing which you decided to go against.
I'd try anything to make this work!
I think this is it:
http://forums.pcper.com/showthread.php?t=444831
Note: Was posted in 2007
Otherwise Google something like "Switch XP to AHCI", lots of hits. The big problem I saw with it is that a lot of the hits show where a person got the whole process to work with their specific system - meaning their particular hardware, chipsets, etc. - and then people that followed couldn't get it to work on theirs.
Good luck! Please post if it works. I'd love to be able to stop having to change BIOS settings at start up ("Let's see, how did I leave this thing?") I love showing off how my ASUS laptop can boot into Hackintosh (it thinks it's a MacBook Pro) but having to tweak the BIOS settings before I do it makes it look harder than it really is to most people.
I think this is it:
Ohh boy!! I tried that out also, but the problem is that is a 4 year old post. The registry used then would be different than what they are today, IMO.
If anyhow anyone could post the LATEST REGISTRY it just might work.
I have tried that 2-3 times with different registries but it just fails :(
Repair install?
Doing a repair install would probably be faster than trying to search how to do it with registry edits...
Or are you saying you can't even get AHCI doing a completely new install?
Are people trying to ask two different things?
