Asus P8P67 Pro B3 - Lan Issue
steveyg_uk
Ok I'll keep this brief.
Problem:- LAN regulary disconnects and reconnets 30 seconds later.
Symptons:- Loose connection to Lan / Internet for around 30 seconds.
Background:- Had this problem with both P8P67 B2 and P8P67 pro boards. I have several other computers connected to the switch (not hub) and they are working fine. Have replaced the lead to no avail. Have even used the same lead in several other computers which works fine.
Config:-
Study
Netgear 8 port SWITCH 10/100/1000
Server
VOIP
PC
Switch connected to lounge hard wired via outdoor sheilded cat6 lead.
Lounge
Router
XBOX 360
Wii
Thoughts - possible compatibility issue between Negear and P8P67 boards?
Ok diving a bit more into this. I have kept logs of when its been happening, and have now started looking at event logs. I wont post it all as there are thousands however it states the following;-
Warning message - date time - source = e1cexpress
Event ID = 27
Intel 82579V Gigabit Network Connection
- Network link is disconnected
Update -
Have tried the following;-
Remove Kaspersky 2011
Ensure ALL power management even OS is disabled
Use IPV4 instead of IPv6 in prefix policies
Disable nativue IPv6
Disable tunnel IPv6
Disable IPv6
netsh interface tcp set global rss=disabled
netsh interface tcp set global autotuninglevel=disabled
netsh int ip set global taskoffload=disabled
Disabled SNP;-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
EnableTCPChimney=dword:00000000
EnableTCPA=dword:00000000
EnableRSS=dword:00000000
All to no avail. Running out of ideas.
Hmmmm think I only have 2 other options left.
Try different switch
Try different PCIe device
Strange, becuase I am using a Netgear 16port switch with a Dlink router without issue- Intel LAN is behaving fine for me. Have you tried the latest drivers from Intel's support site?
Yeah I built P8P67 Pro machine pre-B3 and the NIC came DOA. I ended up having to grab an old PCI NIC because I didn't want to return the MB after the system was put together.
Makes me wonder then if my NIC is faulty.
Not sure if you know my history but this is the 3rd board I have had. At last its all working - very neat build as well. No way I'm gonna send back for a faulty NIC - what a right royal pain in the a**.
I'll try a different switch first me thinks see what happens. I have ran all the INTEL diags all pass ok - very odd.
Those Realtek PHYs really suck (so do most Marvells). I wish they'd stop using them and switch them out for Intel PHYs like the better boards use.
Yeah why the hate towards the realtek nics?
Haven't had any problems with mine.
No problems with the gigabit CSA Intel LAN on my old IC7 max 3 (still in use)
No problems with the Marvell gigabit LAN on my P5wdh deluxe (until i retired the board after burning out the cpu 4 pin 12v.
Not having any problems with my Realtek gigabit on my UD5 (so far).
pop in an old pci nic or get one for like5-10$ that would rule out whther its yr motherboard or outside of yr motherboard
I have flawless working p8p67 pro that i OC yesterday to 4.8 ghz then toned it down to 4.5ghz just on air cooling.
My mistake regarding the Realtek vs Intel PHY on the Pro board - some of the other boards have Realtek PHYs.
I've come across any number of dead on-board LAN ports at work and on my own PCs in the last few years most of them have been either Realtek or Marvell. And besides the dead ports, they have lower throughput, more frequent driver issues and strange intermittent problems. But this is all OT, since the OP's board is not using a Realtek PHY.
1)Try setting full duplex / 1000Mbps manually
Disable TCP/IP flow control (this should help the connection fail earlier)
Disable interrupt moderation
Disable jumbo packets
Enable slave mode
2)If that doesn't work, set it to 1000Mbps / half duplex (if possible, may not be an option)
If that doesn't work, try master mode
I don't think your NICs are bad. "link flapping" is almost always caused by a poor connection and/or one side being pickier about autonegotiation than the other.
Thanks for you help. I'll give that a try.
At the start of the week I have ordered a 1gb PCIe card - wondering if that will solve the problem.
Interesting it MUST be a driver issue as working in safe mode WITH networking, it didn't complain at all.
Works for me: I had a similar issue to steveyg_uk. After reading this thread, I set 1Gbps full duplex (before that it was auto negotiation), disabled interrupt moderation (previously enabled) and forced slave mode (previously auto). Jumbo packets were already disabled so I left them. Since then it has worked perfectly.
- Dave
