DarkBahamut
- Mar 18, 2005
Hi all, I'm having a few problems with a new Sandybridge systems i'm putting together at the moment, mainly related to the hard drive and what seems a lack of UEFI boot support from the EFI BIOS.
So far i've tried just about every google result to get windows 7 x64 to install in EFI mode with a full 3TB available but it simply will not work. It seems Windows setup also boots in BIOS mode and thus will only install with the older MBR type limiting me to ~2TB.
The EFI BIOS has no options to force BIOS or UEFI booting like i've seen in a few screenshots. The board is set to AHCI mode on the SATA ports and i've tried both the Intel 6GB/s ports and the Marvell ports the board also has, none work.
If i manually force the drive into a GPT mode with a 2.8TB partition then Windows setup says it cannot install to a GPT drive. On following advice online i tried making a UEFI only Windows 7 DVD to force a UEFI boot, but the board will not boot this disk at all, leading me to believe there is no UEFI boot support what so ever.
I've also tried updating the motherboard to the most recent BIOS image - no change.
Does anyone have any ideas or know a setting i'm missing somewhere, or is this a motherboard/EFI issue?
Cheers for any help!
